Thickness Gages Series 950,184
Series 950
• Each leaf is marked with its thickness.
• Each leaf is detachable.
Accuracy of Leaves Thickness
Nominal Thickness Tolerance
Metric
0.01mm to less than 0.06mm: ±0.003mm
0.06mm to less than 0.10mm: ±0.004mm
0.10mm to less than 0.35mm: ±0.005mm
0.35mm to less than 0.65mm: ±0.008mm
0.65mm to less than 3.0mm: ±0.01mm
Inch
.0015 to less than .007": ±.0002"
.007 to less than .015": ±.0003"
.015 to less than .025": ±.0004"
.026 to less than .030": ±.00045"
.031 to less than .040": ±.0005"
.041 to less than .075": ±.00055"
.076 to less than .100": ±.0006"
.101 to less than .200": ±.00065"
.200" and over : ±.00075"
InchMetric
Order NoRange# of LeavesLengthCompositionType of Blade
950-251.002-.035in263in0.02 thru 0.18" by 0.01" step plus .022, .024, .025, .028, .030, .032, .035"Straight 1/2in width
950-252.0015-0.025in263in.002 thru .025" by .001" step plus .0015, .0025"Tapered 1/4 width at tip
950-254.0015-.200in153in0.015, 0.02, 0.03, 0.04, 0.06, 0.08, 0.10, 0.12, 0.15, 0.20, 0.30, 0.40, 0.75, .100, .200"Straight 1/2in width
950-255.0015-.200in134 1/2in0.015, 0.02, 0.03, 0.04, 0.06, 0.08, 0.10, 0.20, 0.30, 0.40, 0.75, .100, .200"Straight 1/2in width
950-256.0015-.015in86in0.015, 0.02, 0.03, 0.04, 0.08, 0.10, 0.12, 0.15"Straight 1/2 width
