Tube Micrometers - Series 115
Series 115
  • Designed to measure the wall thickness of various tubing.
  • The Tube Micrometers have two combinations of measuring faces (carbidetipped): spherical-flat type, and spherical type.
  • Cylindrical anvils (perpendicular) are also available.
  • With SPC output (Series 395).
  • With digit counter (Series 295).
  • With a standard bar except 0-25mm and 0-1” model.
(excluding quantizing error for digital models)
Resolution*: 0.001mm or .00005"/0.001mm
Graduation**: 0.01mm, .001" or .0001"
Flatness: 0.6ìm / .000024”
Display*: LCD
Dust/Water protection level*: IP65
Function of Digital Model
Origin-set, Zero-setting, Data hold, Data output, inch/mm
conversion (inch/mm models)
05CZA662: SPC cable with data switch (1m / 40”)
05CZA663: SPC cable with data switch (2m / 80”)
InchMetric
Order NumberImageRangeAccuracyRemarksDescriptMass
115-305-0-1in±0.00015inType A-180g
115-313115-313.jpg0-1in±0.00015inType C.0001 in reading is obtained with verner180g
115-314115-314.jpg0-1in±0.00015inType D.0001 in reading is obtained with verner180g
