Tube Thickness Caliper Series 573,536-ABSOLUTE Digimatic and Vernier Type
Series 573
  • The main scale jaw is a round bar that facilitates measurements of tube wall thickness.
  • With SPC data output. (Series 573)
Display*: LCD
Max. response speed*: Unlimited
Battery life*: Approx. 3.5 years under normal use
Function of Digital Model
Origin-set, Zero-setting, Power On/Off, Data output, inch/mm conversion (inch/mm models)
05CZA624: SPC cable with data switch (40” / 1m)
05CZA625: SPC cable with data switch (80” / 2m)
Order NoImageRange AccuracyResolutionMass
573-761573-761.jpg0-6in 0-150mm.002in.0005in 0.01mm167g
