V-Anvil Micrometers - Series 314, 114 - 3 Flutes and 5 Flutes
Series 314
  • Measures the outside diameter of cutting heads(such as taps,reamers,end mills)
    with odd number of flutes.
  • With Ratchat Stop for constant force.
  • Supplied with setting standard.
  • V-anvils with a centerline grove are available.They are useful for measuring pitch diameters of of taps which have a small diamter by using single-wire method.
  • With SPC output (Series 314).
Resolution*: 0.001mm or .00005"/0.001mm
Graduation**: 0.01mm, .001" or .0001"
Flatness (spindle/anvil):
Analog model: 0.6µm/.000024”, 1.3µm/.00005"
Digital Model: 0.3µm/.000012". 1µm/.00004"
Spindle face: Carbide tipped
Display*: LCD
Battery life*: Approx. 1.2 yrs under normal use
Function of Digital Model
Zero-setting, Data hold, Data output, Preset, inch/mm conversion (inch/mm models)
Function Lock
2 presets
05CZA662: SPC cable with data switch (1m / 40”)
05CZA663: SPC cable with data switch (2m / 80”)
114 Inch114 Metric314 Inch/Metric314 Metric
Order NumberImageRange Inch# of FlutesAccuracy GroveTip DescriptionMass
114-113114-113.jpg1-1.6in3±0.00025in--400g
114-114-1.6-2.2in3±0.0003in--465g
114-135114-135.jpg0.09-1in5±0.0002inCarbide Tipped Anvil-255g
114-163-0.05-0.6in3±0.0002in--120g
114-202114-202.jpg0.09-1in3±0.0002inCarbide Tipped AnvilCarbide Tipped Anvil and .0001 in reading is obtained with vernier280g
line drawings videos
