Series 500
Mitutoyo's Absolute Solar Digimatic Caliper
retains its origin point even if the display turns
off for the entire life of the caliper. At 60
Lux and up the ABSOLUTE solar caliper is, turned on ready to start measurement.
- No more repeated zero setting caused by the shortage of light intensity.
- Hard-coated solar panel for safe operation.
- No fear for overspeed errors.
- With thumb roller.
- Supplied in fitted plastic case.
Repeatability: 0.01mm / .0005”
Length standard:ABSOLUTE electrostatic capacitance type
linear encoder
Battery: Solar battery*
*Can be used continuously above 60 lux ambient illumination.
Origin-set, Data hold, Data output, inch/mm conversion
(inch/ mm models)
Alarm: Counting value composition error
959143: Data hold unit (SPC output model only)
959149: SPC cable with data switch (1m / 40”)
959150: SPC cable with data switch (2m / 80”)
