| 542-171 | 542-161 | 542-172 | 542-162 | 542-612 | 542-173 | 542-163 | 542-613 |
| .4in
10mm | .4in
10mm | 1in
25mm | 1in
25mm | 1in
25mm | 2in
50mm | 2in
50mm | 2in
50mm |
| 0.0005mm | 0.001mm | 0.0005mm | 0.001mm | 0.005mm | 0.0005mm | 0.001mm | 0.005mm |
| (1.5+L/50) | (1.5+L/50) | (1.5+L/50) | (1.5+L/50) | (7.5+l/50)µm | (1.5+L/50) | (1.5+L/50) | (7.5+l/50)µm |
| ±1 count | ±1 count | ±1 count | ±1 count | ±1 count | ±1 count | ±1 count | ±1 count |
upwards-1.0N or less horizontal-1.1N or less downwards 1.2N or lessN | upwards-1.0N or less horizontal-1.1N or less downwards 1.2N or lessN | upwards-4.0N or less horizontal-4.3N or less downwards 4.6N or lessN | upwards-4.0N or less horizontal-4.3N or less downwards 4.6N or lessN | upwards-4.0N or less horizontal-4.3N or less downwards 4.6N or lessN | upwards-4.9N or less horizontal-5.3N or less downwards 5.7N or lessN | upwards-4.9N or less horizontal-5.3N or less downwards 5.7N or lessN | upwards-4.9N or less horizontal-5.3N or less downwards 5.7N or lessN |
| Photoelectric linear encoder | Photoelectric linear encoder | Photoelectric linear encoder | Photoelectric linear encoder | Photoelectric linear encoder | Photoelectric linear encoder | Photoelectric linear encoder | Photoelectric linear encoder |
| 1500mm/s | 1500mm/s | 1500mm/s | 1500mm/s | 1500mm/s | 1500mm/s | 1500mm/s | 1500mm/s |
| 90° phase difference, differential square wave (RS-422A equivalent), minimum edge intervals: 1000ns for
5µm model, 500ns for 1µm model, 250ns for 0.5µm model | 90° phase difference, differential square wave (RS-422A equivalent), minimum edge intervals: 1000ns for
| 2µm | 4µm | 2µm | 4µm | 20µm | 2µm | 4µm | 20µm |
| 260g | 260g | 300g | 300g | 300g | 400g | - | 400g |
| Equivalent to IP66 (only gage head) | Equivalent to IP66 (only gage head) | Equivalent to IP66 (only gage head) | Equivalent to IP66 (only gage head) | Equivalent to IP66 (only gage head) | Equivalent to IP66 (only gage head) | Equivalent to IP66 (only gage head) | Equivalent to IP66 (only gage head) |
| ø3mm carbide-tipped (fixing screw: M2.5 (P=0.45)×5), standard contact point No.901312 | ø3mm carbide-tipped (fixing screw: M2.5 (P=0.45)×5), standard contact point No.901312 | ø3mm carbide-tipped (fixing screw: M2.5 (P=0.45)×5), standard contact point No.901312 | ø3mm carbide-tipped (fixing screw: M2.5 (P=0.45)×5), standard contact point No.901312 | ø3mm carbide-tipped (fixing screw: M2.5 (P=0.45)×5), standard contact point No.901312 | ø3mm carbide-tipped (fixing screw: M2.5 (P=0.45)×5), standard contact point No.901312 | ø3mm carbide-tipped (fixing screw: M2.5 (P=0.45)×5), standard contact point No.901312 | ø3mm carbide-tipped (fixing screw: M2.5 (P=0.45)×5), standard contact point No.901312 |
| ø8mm | ø8mm | ø15mm | ø15mm | ø15mm | ø15mm | ø15mm | ø15mm |
| Linear ball bearing | Linear ball bearing | Linear ball bearing | Linear ball bearing | Linear ball bearing | Linear ball bearing | Linear ball bearing | Linear ball bearing |
| 2m (directly from casing) | 2m (directly from casing) | 2m (directly from casing) | 2m (directly from casing) | 2m (directly from casing) | 2m (directly from casing) | 2m (directly from casing) | 2m (directly from casing) |
| Plug: RM12BPE-6PH (HIROSE), Compatible receptacle: RM12BRD-6S (HIROSE) | Plug: RM12BPE-6PH (HIROSE), Compatible receptacle: RM12BRD-6S (HIROSE) | Plug: RM12BPE-6PH (HIROSE), Compatible receptacle: RM12BRD-6S (HIROSE) | Plug: RM12BPE-6PH (HIROSE), Compatible receptacle: RM12BRD-6S (HIROSE) | Plug: RM12BPE-6PH (HIROSE), Compatible receptacle: RM12BRD-6S (HIROSE) | Plug: RM12BPE-6PH (HIROSE), Compatible receptacle: RM12BRD-6S (HIROSE) | Plug: RM12BPE-6PH (HIROSE), Compatible receptacle: RM12BRD-6S (HIROSE) | Plug: RM12BPE-6PH (HIROSE), Compatible receptacle: RM12BRD-6S (HIROSE) |
| 0 to 40°C (RH 20 to 80%, no condensation) | 0 to 40°C (RH 20 to 80%, no condensation) | 0 to 40°C (RH 20 to 80%, no condensation) | 0 to 40°C (RH 20 to 80%, no condensation) | 0 to 40°C (RH 20 to 80%, no condensation) | 0 to 40°C (RH 20 to 80%, no condensation) | 0 to 40°C (RH 20 to 80%, no condensation) | 0 to 40°C (RH 20 to 80%, no condensation) |
| –10 to 60°C (RH 20 to 80%, no condensation) | –10 to 60°C (RH 20 to 80%, no condensation) | –10 to 60°C (RH 20 to 80%, no condensation) | –10 to 60°C (RH 20 to 80%, no condensation) | –10 to 60°C (RH 20 to 80%, no condensation) | –10 to 60°C (RH 20 to 80%, no condensation) | –10 to 60°C (RH 20 to 80%, no condensation) | –10 to 60°C (RH 20 to 80%, no condensation) |
