STRATO-Apex 500/700/900 Series 355-High Accuracy CNC CMM
Series 355
The STRATO-Apex series is high-accuracy CNC CMMs achieving 0.9μm for the first term. The series guarantees high accuracy and also high moving speed and acceleration achieved with improved rigid air bearings on all axial guideways. The scale systems on Mitutoyo high-precision models utilizes a high-performance linear encoder (manufactured by Mitutoyo), for detecting axis position. In addition, various technologies have been utilized in the structure, part processing, and assembly to provide high accuracy measurement .
* 18-22°C (64.4-71.6°F - Strato Apex 574
** 19-21°C (66.2-69.8°F) - Strato Apex 776/7106/9106/9766
STRATO-Apex
ModelSTRATO-Apex 574STRATO-Apex 776STRATO-Apex 7106STRATO-Apex 9106STRATO-Apex 9166
Order No.355-522-01355-502355-507355-512355-517
TypeMoving Bridge Type
High Accuracy
Moving Bridge Type
High Accuracy
Moving Bridge Type
High Accuracy
Moving Bridge Type
High Accuracy
Moving Bridge Type
High Accuracy
ImageSTRATO-A574.jpgStrato700s.jpg-Strato900s.jpg-
X-axis19.7" (500mm)27.6" (70mm)27.6" (700mm)35.4" (900mm)35.4" (900mm)
Y-axis27.6" (700mm)27.6" (700mm)39.4" (1000mm)39.4" (1000mm)63.0" (1600mm)
Z-axis15.7" (400mm)23.6" (600mm)23.6" (600mm)23.6" (600mm)23.6" (600mm)
Resolution0.0000019" (0.00005mm)0.0000008" (0.00002mm)0.0000008" (0.00002mm)0.0000008" (0.00002mm)0.0000008" (0.00002mm)
Material GraniteGraniteGraniteGraniteGranite
Work Table Size26.61"x55.90"
(676mm x 1420mm)
33.93" x 55.90"
(862mm x 1420mm)
33.93" x 67.71"
(862mm x 1720mm)
41.81" x 67.71"
(1062mm x 1720mm)
41.81" x 91.33"
(1062mm x 2320)
Tapped InsertM8x1.25mmM8x1.25mmM8x1.25mmM8x1.25mmM8x1.25mm
Max. Workpiece Height 22.04" (560mm)30.31" (770mm)30.31" (770mm)30.31" (770mm)30.31" (770mm)
Max. Workpiece Weight396lbs (180kg)1102lbs (500kg)1763lbs (800kg)1763lbs (800kg)2645lbs (1200kg)
Mass (including stand and controller)3373lbs (1530kg)4177lbs (1895kg)4806lbs (2180kg)5313lbs (2410kg)6801lbs (3085kg)
Machine Dimensions WxDxH50.00 x 64.96 x 94.88"
(1270 x 1650 x 1270mm)
57.48 x 73.22 x 111.41"
(1460 x 1860 x 1460mm)
57.48 x 85.03 x 111.41"
(1460 x 2160 x 1460mm)
65.35 x 85.03 x 111.41"
(1660 x 2160 x 1660mm)
65.35 x 108.66 x 111.41"
(1660 x 2760 x 1660mm)
ISOISO-10360-2:2009 E0,MPE
TP200: (1.4+2.5L/1000)μm*
SP25: (0.7+2.5L/1000)μm*
ISO-10360-2:2009 E150,MPE
TP200: (1.9+2.5L/1000)μm*
ISO-10360-2:2009 R0,MPL
TP200: 1.2μm*
SP25: 0.7μm*
ISO-10360-4: 2000
MPETHP/MPTTHP
SP25: 1.3μm/40sec*
ISO-10360-5: 2010 PFTU,MPE
SP25: 0.7μm*
TP200: 1.8μm*
TP200: (1.4+2.5L/1000)μm**
SP25: (0.9+2.5L/1000)μm**
TP200: (1.9+2.5L/1000)μm**
TP200: 1.2μm*
SP25: 0.8μm*
ISO-10360-4: 2000 MPETHP/MPTTHP
SP25: 1.8μm/45sec*
SP25: 0.9μm*
TP200: 1.8μm*
TP200: 1.2μm*
SP25: 0.8μm*
ISO-10360-4: 2000
MPETHP/MPTTHP
SP25: 1.8μm/45sec*
SP25: 0.9μm*
TP200: 1.8μm*
TP200: (1.5+2.5L/1000)μm**
TP200: (2.0+2.5L/1000)μm**
TP200: 1.2μm*
SP25: 0.8μm*
ISO-10360-4: 2000
MPETHP/MPTTHP
SP25: 1.8μm/45sec*
SP25: 0.9μm*
TP200: 1.8μm*
TP200: 1.2μm*
SP25: 0.8μm*
ISO-10360-4: 2000
MPETHP/MPTTHP
SP25: 1.8μm/45sec*
SP25: 0.9μm*
TP200: 1.8μm*
literature accessories
